iCAx开思工具箱
 立即注册
QQ登录
只需一步,快速开始
查看: 25453|回复: 5
UF_MODL_create_replace_face调试不过,急!
楼主
发表于 2008-4-29 18:48:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
马上注册登录,享用更多网站功能!
您需要 登录 才可以下载或查看,没有帐号?立即注册
//代码如下:
#include <stdio.h>
#include <uf.h>
#include <uf_defs.h>
#include <uf_exit.h>
#include <uf_ui.h>
#include <uf_styler.h>
#include <uf_mb.h>
#include <time.h>
#include <windows.h>
#include <string.h>
#include <uf_modl.h>
#include <uf_part.h>
#include <uf_obj.h>
#include <uf_object_types.h>
#include <uf_disp.h>
#include <uf_csys.h>
#include "Replace.h"
extern "C" DllExport void ufsta( char *param, int *returnCode, int rlen )
    /* Initialize the API environment */
    int errorCode = UF_initialize();
    if ( 0 == errorCode )
        /* TODO: Add your application code here */
                char *message1 = "Select Target Faces";
                char *message2 = "Select Tool Face";
                int rsp1, rsp2, count=0;
                int num_non_blend=0;
                int irc = 0,response;
                int k = 0;
                double cursor[3];
                tag_t *target;
                tag_t *non_blend_faces;
                tag_t tool_face = NULL_TAG;
                tag_t feature_tag = NULL_TAG;
                tag_t view;
                logical reverse_direction=FALSE;
                UF_UI_selection_options_t opts;
                UF_UI_mask_t mask = {UF_face_type, 0, 0};
                opts.other_options = 0;
                opts.reserved = NULL;
                opts.num_mask_triples = 1;
                opts.scope = UF_UI_SEL_SCOPE_WORK_PART;
                opts.mask_triples = &mask;
                UF_UI_select_by_class( message1,&opts,&rsp1,&count,&target );
                if (rsp1 == 3)
                        for (k=0; k < count; k++)
                                UF_DISP_set_highlight(target[k],0);
                        opts.scope = UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY;
                        irc = UF_UI_select_single(message2,&opts,&response,
                                &tool_face,cursor,&view);
                        if (response == 4 || response == 5)
                                UF_DISP_set_highlight(tool_face,0);
                                int resp = UF_MODL_create_replace_face(
                                        target,
                                        count,
                                        non_blend_faces,
                                        num_non_blend,
                                        tool_face,
                                        reverse_direction,
                                        &feature_tag );
                                char message[256];
                                if(resp)
                                        sprintf(message,"%d", resp);
                                        uc1601(message, 1);
                                        UF_get_fail_message(resp, message);
                                        uc1601(message, 1);
        /* Terminate the API environment */
        errorCode = UF_terminate();
extern "C" int ufusr_ask_unload( void )
    return( UF_UNLOAD_IMMEDIATELY );
--------------------Configuration: Replace - Win32 Debug--------------------
Compiling...
Replace.cpp
E:\UGOPEN\QuickElectrodeV7\Replace\Replace.cpp(70) : error C2065: 'UF_MODL_create_replace_face' : undeclared identifier
执行 cl.exe 时出错.
Replace.dll - 1 error(s), 0 warning(s)
收藏收藏 分享淘帖 支持支持
沙发
发表于 2008-4-30 05:33:32 | 只看该作者
马上注册登录,享用更多网站功能!
板凳
发表于 2008-4-30 11:18:03 | 只看该作者
马上注册登录,享用更多网站功能!
地板
 楼主| 发表于 2008-4-30 12:52:06 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2008-4-30 13:18:09 | 只看该作者
马上注册登录,享用更多网站功能!
 楼主| 发表于 2008-4-30 13:25:13 | 只看该作者
马上注册登录,享用更多网站功能!
您需要登录后才可以回帖 登录 | 立即注册
手板模型制作,在线3D打印服务
小黑屋|手机版|开思工具箱 CAD工具箱_CAM工具箱
GMT+8, 2025-10-21 19:54 , Processed in 0.018217 second(s), 6 queries , Gzip On, Redis On.
