iCAx开思工具箱
 立即注册
QQ登录
只需一步,快速开始
查看: 25315|回复: 8
【求助】生成二维视图中出现的问题。
楼主
发表于 2003-6-6 11:55:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
马上注册登录,享用更多网站功能!
您需要 登录 才可以下载或查看,没有帐号?立即注册
下面是一个生成二维视图的 c文件,编译时没错,链接时出现如下错误,请各位大侠帮忙,先谢了!
Linking...
DrawingFromTmpltCreate.obj : error LNK2001: unresolved external symbol _ProUtilWstrcpy
Debug/MouldCAD.dll : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
MouldCAD.dll - 2 error(s), 3 warning(s)
//UserDrawingCreateDemo.c
#include &ltroToolkit.h>
#include &ltroDrawing.h>
#include &ltroMdl.h>
#include <TestError.h>
#include "UtilString.h"
#include "roWstring.h"
#include "roUtil.h"
#include "DrawingFromTmpltCreate.h"
#define TEMPLATE_NAME "c_drawing"
FUNCTION: UserDrawingCreateDemo()
PURPOSE:  Creates a drawing for the current model.
  int UsrDrawingCreateDemo()
 &nbsproError      err;
 &nbsproMdl        solid_mdl;
 &nbsproMdlType    mdl_type;
 &nbsproMdldata    data;
 &nbsproModel      model;
  // ProFileName   msgfil;
  ProName       predefined_template;
  ProName       name;
  ProDrawing    created_drawing;
  ProDwgcreateOptions options = (ProDwgcreateOptions)0;
  ProDwgcreateErrs  errors;
    created_drawing = NULL;
  Set up the name of the message file.
  //ProStringToWstring (msgfil, "msg_ugdrawing.txt");
  Use the current model to create the drawing.
  err = ProMdlCurrentGet ([$solid_mdl)]
  if (err != PRO_TK_NO_ERROR)
      return (err);
  err = ProMdlTypeGet (solid_mdl, [$mdl_type)]
  if (err != PRO_TK_NO_ERROR ||
      (mdl_type != PRO_MDL_PART && mdl_type != PRO_MDL_ASSEMBLY))
       return PRO_TK_INVALID_TYPE;
    err = ProMdlDataGet (solid_mdl, [$data)]
  ProUtilWstrcpy(model.name,data.name);
  ProUtilWstrcpy (model.type,data.type);
  Initialize the template name.
  ProStringToWstring (predefined_template, TEMPLATE_NAME);
  Read in the root of the new name of the drawings to create.
  // err = ProMessageDisplay (msgfil, "USER Enter new drawing name: ");
  err = ProMessageStringRead (PRO_NAME_SIZE, name);
      return (err);
  Create the required drawing.
  err = ProDrawingFromTmpltCreate (name, predefined_template,
                                    &model, options, &created_drawing,
                                    [$errors)]
  if (err != PRO_TK_NO_ERROR || err != PRO_TK_DWGCREATE_ERRORS)
    return err;
  //if (err == PRO_TK_DWGCREATE_ERRORS)
      //ProMessageDisplay (msgfil,"USER Errors found when creating drawing %w", name);
  return (PRO_TK_NO_ERROR);
收藏收藏 分享淘帖 支持支持
沙发
发表于 2003-6-6 17:21:06 | 只看该作者
马上注册登录,享用更多网站功能!
板凳
发表于 2003-6-6 18:12:46 | 只看该作者
马上注册登录,享用更多网站功能!
地板
发表于 2003-6-17 20:58:20 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2003-6-17 22:35:32 | 只看该作者
马上注册登录,享用更多网站功能!
 楼主| 发表于 2003-6-18 16:51:53 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2003-6-20 13:53:50 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2003-6-20 22:21:16 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2003-6-24 09:50:36 | 只看该作者
马上注册登录,享用更多网站功能!
您需要登录后才可以回帖 登录 | 立即注册
手板模型制作,在线3D打印服务
GMT+8, 2025-9-12 02:28 , Processed in 0.022213 second(s), 16 queries , Gzip On, Redis On.
