iCAx开思工具箱
 立即注册
QQ登录
只需一步,快速开始
查看: 1648|回复: 1
[技术交流] NXOpen C# 创建曲线
楼主
发表于 2018-12-20 11:18:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
马上注册登录,享用更多网站功能!
您需要 登录 才可以下载或查看,没有帐号?立即注册
using System;
using System.IO;
using NXOpen;
using NXOpen.UF;
namespace NetExample
/// <summary>
/// Summary description for EX_Curve_CreateArc.
/// </summary>
public class EX_Curve_CreateArc
        private static FileStream fs;
        private static StreamWriter w;
        private static UFSession theUfSession;
        private static Session theSession;
        public int Execute()
            Tag UFPart;
            string part_name = "EX_Curve_CreateArc";
            int units =2;
            string name;
            theUfSession.Part.New(part_name, units, out UFPart);
            theUfSession.Part.AskPartName(UFPart, out name);
            w.WriteLine("Loaded: " + name);
            Tag arc, wcs;
            UFCurve.Arc arc_coords = new UFCurve.Arc();
            /* Fill out the data structure */
            arc_coords.start_angle = 0.0;
            arc_coords.end_angle = 3.0;
            arc_coords.arc_center=new double[3];
            arc_coords.arc_center[0] = 0.0;
            arc_coords.arc_center[1] = 0.0;
            arc_coords.arc_center[2] = 1.0;
            arc_coords.radius = 2.0;
            theUfSession.Csys.AskWcs(out wcs);
            theUfSession.Csys.AskMatrixOfObject(wcs,out arc_coords.matrix_tag);
            theUfSession.Curve.CreateArc(ref arc_coords,out arc);
            theUfSession.Part.Save();
            return 0;
        public static void Main(string[] args)
            theSession=Session.GetSession();
            theUfSession= UFSession.GetUFSession();
            fs = new FileStream("EX_Curve_CreateArc.log", FileMode.Create, FileAccess.Write);
            w = new StreamWriter(fs); // create a stream writer
            w.Write("Log Entry : \r\n");
            w.WriteLine("--Log entry goes here--");
            w.Flush(); // update underlying file
   if ( File.Exists("EX_Curve_CreateArc.prt") )
    w.WriteLine("Remove EX_Curve_CreateArc.prt file from <Project Folder>\\bin\\Debug !!");
    w.WriteLine("EX_Curve_CreateArc.prt already exists. !!");
    w.Close();
    return;
            try
                EX_Curve_CreateArc curveTest1 = new EX_Curve_CreateArc();
                if (curveTest1.Execute()==0)
                    w.WriteLine("Successful");
                else
                    w.WriteLine("Failed");
            catch(NXException e)
                w.WriteLine("Exception is: {0}", e.Message);
            w.WriteLine("End of Log File");
            w.Close();
  public static int GetUnloadOption(string dummy)
   return UFConstants.UF_UNLOAD_IMMEDIATELY;
收藏收藏 分享淘帖 支持支持
沙发
 楼主| 发表于 2018-12-20 11:23:27 | 只看该作者
马上注册登录,享用更多网站功能!
您需要登录后才可以回帖 登录 | 立即注册
手板模型制作,在线3D打印服务
GMT+8, 2024-9-21 08:56 , Processed in 0.011352 second(s), 7 queries , Gzip On, Redis On.
© 2002-2024 www.iCAx.org
