iCAx开思工具箱
 立即注册
QQ登录
只需一步,快速开始
查看: 27663|回复: 20
【讨论】pro/e二次开发如何实现这个函数功能
楼主
发表于 2003-7-6 12:56:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
马上注册登录,享用更多网站功能!
您需要 登录 才可以下载或查看,没有帐号?立即注册
TOOl的例子里,想void Check() 功能,获取当前零件的孔的列表
  typedef struct surface_visit_data
   FILE      *fp;
   ProSolid   part;
} AxisVisitData_t;
FUNCTION:  UserDemoAxisAct()
PURPOSE :  Axis-visit action function that writes the
            axis name to a file
ProError UserDemoAxisAct(
     ProAxis     axis,
     ProError    filt_status,
     ProAppData  app_data)
     ProError          status;
     AxisVisitData_t  *p_data = (AxisVisitData_t*)app_data;
     ProSolid          part = p_data->part;
     FILE             *fp = p_data->fp;
     int               id;
     ProModelitem      modelitem;
     ProFeature        feature;
     ProFeattype       ftype;
     ProName           wname;
     char              name[PRO_NAME_SIZE];
     ProSelection      selection;
     Get the axis identifier.
     status = ProAxisIdGet (axis, [$id)]
     if (status != PRO_TK_NO_ERROR)
         return (status);
     Make a ProModelitem handle for the axis.
     status = ProModelitemInit (part, id, PRO_AXIS, [$modelitem)]
         return (status);
     Get the feature to which the axis belongs.
     status = ProGeomitemFeatureGet ([$modelitem, &feature)]
         return (status);
     Get the feature type.
     status = ProFeatureTypeGet ([$feature, &ftype)]
         return (status);
     If the type was not HOLE, skip it.
  if (ftype != PRO_FEAT_HOLE )
        return (PRO_TK_NO_ERROR);
     Get the name of the axis.
     status = ProModelitemNameGet ([$modelitem, wname)]
         return (status);
     ProWstringToString (name, wname);
     Print out the axis name and hole identifier.
     fprintf (fp, "Axis %s belongs to hole feature %d\n", name,
              feature.id);
     Highlight the owning hole.
     ProSelectionAlloc (NULL, [$feature, &selection)]
     ProSelectionHighlight (selection, PRO_COLOR_HIGHLITE);
     ProSelectionFree ([$selection)]
FUNCTION:  UserDemoHoleList()
PURPOSE:   List the axes that belong to the hole features in
            a part, and report their names.
ProError UserDemoHoleList(
     ProSolid         part)
     ProError         status;
     AxisVisitData_t  data;
     data.part = part;
     Open the text file.
     data.fp = fopen ("visit_test.dat","w");
     Visit all the axes using the visit and filter functions
     above. Pass the owning solid and the text file pointer
     using the app_data argument.
     status = ProSolidAxisVisit (part, UserDemoAxisAct,
                                 NULL, (ProAppData)[$data)]
     Close the file
     fclose (data.fp);
这个函数为帮助中的Example 5: Listing Holes in a Model
如何将这段代码加入void Check()
收藏收藏 分享淘帖 支持支持
沙发
 楼主| 发表于 2003-7-7 12:44:36 | 只看该作者
马上注册登录,享用更多网站功能!
板凳
 楼主| 发表于 2003-7-7 12:47:29 | 只看该作者
马上注册登录,享用更多网站功能!
地板
 楼主| 发表于 2003-7-7 12:49:26 | 只看该作者
马上注册登录,享用更多网站功能!
 楼主| 发表于 2003-7-8 08:28:39 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2003-7-8 13:00:04 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2003-7-8 14:21:29 | 只看该作者
马上注册登录,享用更多网站功能!
 楼主| 发表于 2003-7-8 18:17:31 | 只看该作者
马上注册登录,享用更多网站功能!
发表于 2003-7-8 22:02:32 | 只看该作者
马上注册登录,享用更多网站功能!
 楼主| 发表于 2003-7-8 23:15:22 | 只看该作者
马上注册登录,享用更多网站功能!
您需要登录后才可以回帖 登录 | 立即注册
手板模型制作,在线3D打印服务
GMT+8, 2024-9-28 03:19 , Processed in 0.014186 second(s), 6 queries , Gzip On, Redis On.
© 2002-2024 www.iCAx.org
